Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
9 members (cmayna, FAST55, Shaffer's1950, Hanks custodian, JW51, 32vsnake, Gib70, JD1, 1 invisible), 514 guests, and 2 robots.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
#534967 05/05/2009 1:07 PM
Will someone send me some pics of Original Equipment Cab Clearance Lights? I want to see if mine are original and of the correct type.
Thanks!
I just took a set off a 65, and without looking, I remember Yankee 77, or something similar, in the top of the casting. I don't know for sure that they're factory originals, but they look the same as all the others I've seen.
Yankee 77's are the original type.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Yankees they are! Thanks!
Y
Y Offline
Yes, Yankee 77's are the correct ones. I believe the options were to have 2 on the corners only, 3 in the middle only, or 5 (3 in the middle and 2 on the corners).
there are 2 nos 1s on e-bay right now
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.139s Queries: 14 (0.075s) Memory: 0.6114 MB (Peak: 0.6610 MB) Data Comp: Zlib Server Time: 2025-09-22 15:14:29 UTC
Valid HTML 5 and Valid CSS
