6 members (Robert Crandall, Hotrod Lincoln, 3800GUY, JW51, Wally / Montana, 1 invisible), 78 guests, and 2 robots.
Topics128,082
Posts1,055,961
Members48,430
#535113 05/06/2009 12:57 AM
Is the 4 speed transmission the same on the 1/2 ton and 3/4 the same on the 1948 thrue the 1953 Chevy pickup? If the same, is the u-joint the same going out of the transmission?
Both transmissions are the same, SM420.
No, the front u-joint is different on the three quarter ton than on the half ton.
DG
Denny G
Sandwich, IL
The transmissions are the same but different. The 1/2 ton units are set up for a torque tube, while the 3/4 ton units were set up for a driveshaft. I believe the 3/4 ton open driveline transmissions were used in the 1/2 tons starting in 54 or 55.
3/4 tons had a torque tube from the transmission to the carrier bearing on those years. Only the back half of the drive shaft was open.
Steve
'49 3800
'52 3600
'57 3100
also the big truck SM420 used a parking brake that was mounted to the rear of the transmission.
