2 members (TexasA&M48Truck, Otto Skorzeny), 58 guests, and 3 robots.
Topics128,022
Posts1,055,381
Members48,422
#534802 05/04/2009 8:54 PM
dont know if this is the right spot for this post but here goes.i bought a fram HPG1 fuel filter off EBAY for 15.00 so it was a good deal.its a canister type that has a cartridge that you replace.the whole thing is about the size of a oil filter.i cut a piece of 3/16 steel plate to set flush inside my framerails between the tranny mount and rear cab mounts and am going to weld it in flush.now my question is can i drill and tap the plate for 3/8 bolts ?will that alone be strong enough to hold the filter or should i just drill a 3/8 hole and put nuts behind them? thanks.......... dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
As a general rule threads reach their full capacity once the engagement is equal to the diameter. For example if a ½” bolt is engaged by ½”of depth it has reached it’s maximum shear strength and doesn’t get any stronger if threaded any deeper than that. Since your amount of engagement is ½ of the bolt diameter you could expect holding capacity to be reduced by 50%. IMO this is adequate for your application.
You Tube
why not do both. drill and tap then put a nut on the back side to be safe, if you can get to it with a wrench. sounds like the filter won't be that heavy so i bet curt is right and it would hold just fine.
If the back is enclosed denying wrench access, here's a suggestion. Weld nutplates on the bracket before welding it on.
well what i ended up doing was go ahead and drilled 3/8 holes put bolts through them then tightened nuts down and welded them to the backside.pretty much the direction cletis was going.just didnt feel good about just tapping 3/16.thanks guys........dave
1949 Chevrolet 3100
David,
That's an easy way to do it. If you didn't coat the threads with Never-seize before welding, they could be a bear to take apart.
The welding process shrinks the nut and often screws the threads up as you try to remove the bolt...if you can remove the bolt.
Stuart
Stuart is spot on about the out of round condition. Run your tap thru the welded nut and use a bit of oil as dry will tire your tap quickly.
You Tube
