3 members (MickeyP, Greg_H, GA Boy), 105 guests, and 3 robots.
Topics128,169
Posts1,057,035
Members48,458
The stock fan on my Grumman 292 cools well, the dash gauge moving up maybe 25% from cold. Switched over to an electric fan, a 1400CFM Hayden with an adjustable thermostat control.
The quiet was a relief, I could hear all the creaks and rattles that will be fun to try to eliminate....BUT.... the temp gauge ran right up to about 70%. The fan was set up as a pusher, and is only 100CFM less than their highest flow fan [and 1/2 the cost]. With it installed, there isnt room for mounting an additional electric fan.
Should I look into aftermarket flex fan blades? Installing a thermo clutch will require the radiator to be moved, and a new fan to be purchased. Are the flex fans quieter, with some fuel mpg and performance gains while providing adequate cooling?
Or, a firewall insulation campaign. Seriously guys, this thing is NOISY!
Riding in the Passing Lane
The flex fans are noisier then the stock fan. 1400 is not enough. I understand they are not as effective as a pusher then as a puller. I run a 2800 CFM Flex-a-lite on my 70 with 350. Seems to work good but is noisy when it comes on.
1972 Chevy c10 Cheyenne Super
I think I will go with firewall insulation. The cost of failure is negligible.
