3 members (sssammm, Bill Hanlon, Otto Skorzeny), 40 guests, and 3 robots.
Topics128,035
Posts1,055,445
Members48,422
#534250 05/02/2009 6:15 PM
i have a 54 235 the rear cam steel plug is 2 7/64 in dia there is a casting hole in the back of the block that looks to be for a freeze plug it is steped and the outer step id is 2.00 dia. I recieved this block from a machine shop and was not the person on the tear down also would you use the rope rear main seal or the neoprene lip style
eliminatethis #534259 05/02/2009 6:54 PM
The stepped hole is for a freeze plug. It is the flatter style, not the cup style.
Joe W. #534261 05/02/2009 7:12 PM
do you know the amount of press
eliminatethis #534276 05/02/2009 8:32 PM
They are convex plugs which you flatten out in place.
If your rear main cap still has shims under it you will need to use a rope seal.
My Blog
Pre '68 Dave #534288 05/02/2009 9:21 PM
I did not take the crank out but I did buy a shim kit & rope seal also a lip seal I just plastigaged the mains rear was .0025 trust main was .0015 #2 main was .0015 front main was .0015 the crank was turned .010/.010 is that ok also caps were at o clearance to block and torqed
Pre '68 Dave #534289 05/02/2009 9:24 PM
do you have a doorman or any other part # for that convex plug napa has no listing for it
eliminatethis #534294 05/02/2009 9:45 PM
Jim Carter has the set, part no. MEE254 for $6.60
Joe W. #534710 05/04/2009 1:42 PM
thanks
