| | | Forums66 Topics128,013 Posts1,055,322 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | I know its been talked about but I couldn't find the answer to my question, so here it is.
I just got 2 of the carter webers that Tom Langdon sells but after putting them on I realized that I don't know how to wire the chokes. I don't know what it means by "keyed" especially with the 46 having the stock pedal starter. Do I tap into the wire from the ignition to the coil? or can I tap ?????? Help
Oh yeah I am running a 56 235 with a mini HEI fenton intake and exhaust.
Thanks everyone
1946 1/2 ton I'm not addicted I just don't know when to stop
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You could tap into that wire but it would be better to run a new wire from the same switch terminal that wire is on. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | ''keyed'' means that when you turn on the ignition key to start the truck yes you have a foot starter ... but anything else that runs ''off'' that switch after you turn it to a 'run position' would be a place to tap into. do as cletis said and tap off the switch lug. if a run wire goes to a small circuit panel or fused panel that would be a better place to have the choke wired to. be sure to lable or make a diagrahm of your work for furture reference.
some guys don't want a fuse panel and wish their truck 'as stock' as possible. in this modern day where many of our accessories 'run' off something, it's nice to have a way to fuse a radio or wipers or choke.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 12v or 6v truck? (I ask this, just to know - the chokes are rated for 12v systems, if that really matters)
generator or alternator? (I ask this, because some alternators had a post for providing power to electric chokes)
On a 6v system with dual Carter-Webers and electric chokes (from Langdon's), I am running a hot lead from the voltage regulator. The lead has a 10-amp in-line fuse to an oil-pressure switch (that comes "on" at 4 psi). The output lead from the switch is split into two lines - one to each choke.
There is a need for an additional 1/8" NPT T-fitting in the oil filter line (that already has a T-fitting for a line to the oil pressure gauge).
Oil Pressure Switch Part No.: NAPA: MPE OP6626SB
This seems to work fine at 6v (the chokes are mode for 12v). The chokes are heated only when the engine is running (producing 4 psi oil pressure or better). It's a pretty clean set up with no need to run a lead from the engine compartment to under the dash.
| | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Ok so I think I get it. I was thinking of doing like tclederman did and running a hot lead off the voltage regulator and getting an oil pressure switch. Unless someone else has a better idea??
By the way I am running a 12v system with a generator
Thanks again everyone
Brian
