0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 14 Member | | Member Joined: Nov 2001 Posts: 14 | During reassembly (1952 Chevy 1/2 ton), I forgot to put on the new ball collar oil seal. Is it critical enough to go back and put it on? It did not have one on when I took it apart. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | The ball needs a little lube , so it don't bind when the diff goes up and down ,, The oil in the ball is also critical for the U joint lubrication ......... So , if you don't mind it leaking ....... | | |
