1 members (Dusty53), 174 guests, and 4 robots.
Topics128,101
Posts1,056,180
Members48,436
#5337 08/03/2002 7:48 PM
During reassembly (1952 Chevy 1/2 ton), I forgot to put on the new ball collar oil seal. Is it critical enough to go back and put it on? It did not have one on when I took it apart.
#5338 08/03/2002 9:47 PM
The ball needs a little lube , so it don't bind when the diff goes up and down ,,
The oil in the ball is also critical for the U joint lubrication .........
So , if you don't mind it leaking .......
