5 members (NJC, baldeagle, Bill Hanlon, Peggy M, carbking), 53 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#533774 05/01/2009 1:37 AM
I know its been talked about but I couldn't find the answer to my question, so here it is.
I just got 2 of the carter webers that Tom Langdon sells but after putting them on I realized that I don't know how to wire the chokes. I don't know what it means by "keyed" especially with the 46 having the stock pedal starter. Do I tap into the wire from the ignition to the coil? or can I tap ?????? Help
Oh yeah I am running a 56 235 with a mini HEI fenton intake and exhaust.
Thanks everyone
1946 1/2 ton
I'm not addicted I just don't know when to stop
You could tap into that wire but it would be better to run a new wire from the same switch terminal that wire is on.
Cletis #533862 05/01/2009 4:45 AM
''keyed'' means that when you turn on the ignition key to start the truck
yes you have a foot starter ... but anything else that runs ''off'' that switch after you turn it to a 'run position' would be
a place to tap into. do as cletis said and
tap off the switch lug. if a run wire goes to a small circuit panel or fused panel that would be a better
place to have the choke wired to. be sure to lable or make a diagrahm
of your work for furture reference.
some guys don't want a fuse panel and wish their truck 'as stock' as
possible. in this modern day where many of our
accessories 'run' off something, it's nice to have a way to fuse a radio or wipers or choke.
Jim & Caroline
12v or 6v truck? (I ask this, just to know - the chokes are rated for 12v systems, if that really matters)
generator or alternator? (I ask this, because some alternators had a post for providing power to electric chokes)
On a 6v system with dual Carter-Webers and electric chokes (from Langdon's), I am running a hot lead from the voltage regulator. The lead has a 10-amp in-line fuse to an oil-pressure switch (that comes "on" at 4 psi). The output lead from the switch is split into two lines - one to each choke.
There is a need for an additional 1/8" NPT T-fitting in the oil filter line (that already has a T-fitting for a line to the oil pressure gauge).
Oil Pressure Switch Part No.: NAPA: MPE OP6626SB
This seems to work fine at 6v (the chokes are mode for 12v). The chokes are heated only when the engine is running (producing 4 psi oil pressure or better). It's a pretty clean set up with no need to run a lead from the engine compartment to under the dash.
Ok so I think I get it. I was thinking of doing like tclederman did and running a hot lead off the voltage regulator and getting an oil pressure switch. Unless someone else has a better idea??
By the way I am running a 12v system with a generator
Thanks again everyone
Brian
1946 1/2 ton
