0 members (),
171
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 36 | I have a 47 3/4 ton chevy with a 235 in it that needs to be rebuilt, I want to replace it with a moderne 292 and keep my 4speed trans and running gear. Has anyone done this yet they sell the motor mounts but I cant find a bellhouseing adapter. what do I need and is it woth it.
| | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I'm not 100% sure, others will chime in, but here is my understandings. It sounds as though you've found motor mounts, probably side? mounts. The bellhousing flange on a 292 is the same as a smallblock. Of this I can say for sure. I assume your trans mounts are on the bellhousing, as the later trucks are. I believe the SM420 4 speed uses the same mounting pattern in the front whether it is open or closed driveline. That would make me believe that a bell housing from a 55.2 to 66 V8 truck or 63-66 straight 6 will work on both ends.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Which '47 do you have, Art Deco body or Advance Design? It does make a difference. On the Art Deco truck, the clutch and brake pedals mount to the bellhousing, whcih makes things more difficult. If it is the Advance Design, then doing the bellhousing swap should work. I beleive that some alterations to the crossmember is needed to use that bellhousing, as they are shaped different. Another option would be to consider a 261, which is a bolt in using the existing bellhousing.
Bill Burmeister | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Which transmission do you have? Isn't the '47 4-speed the old crashbox version regardless of wether you have an Art Deco or an Advance Design? If so the later bellhousing that fits the motor you want to use won't fit the transmission. You need an SM420 which was used '48 to 60-something instead.
If it currently has a 235 in it someone swapped the motor, and may have already updated the transmission.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 36 | This is true my grandpa had this p/u from before I was born he paid $75 for it. Grand pa put in the 235 it had the 216 and a 3 speed trans. Gramps put in the 4 speed I think out of a 49 but I'm not sure. I just started this project, the truck ran when gramps parked it in 1983. I'm only going to do the money dump thing to keep it in the family. | | | | | Joined: Apr 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 36 | I found some side motor mounts that will work from stovebolters for $125. I want to update the engine but keep the outher gear just to save $. If I have to I will change the trans over to a modern type of 5 speed. | | | | | Joined: Apr 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 36 | I don't know if I have the art deco or advanced design is there an easy way to tell. This beautiful P/U is a real pice of work some friends call it yard art. They think it will never run again so I'm on a mission. thanks for any and all help I'm going to need a lot more info. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The art deco looks like a 46 on back, & the Advance design looks like a 48 up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Take a peak in the galary here and tell us which it looks like, a '46 or a '48...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 36 | O.K. Thanks I have an advanced design 1947. I'm going to start looking for a replacement engine at my local pick a part yard. I want to find a 292 and I have no time line so I'm going to try and be picky. The bellhousing I need might be hard to find also. The Trans in the truck is a SM420 the engine 235. | | |
