6 members (Otto Skorzeny, klhansen, sron48, Hotrod Lincoln, Shade Baby, Phak1), 86 guests, and 4 robots.
Topics128,041
Posts1,055,483
Members48,424
#533431 04/29/2009 7:11 PM
A previous owner has glued a fuzzy type material onto the inside of the cab,around the rear window,etc.What would be the best way to remove the adhesive off the metal?
BC52 #533436 04/29/2009 7:24 PM
Test the following (in the order shown) on a hidden location, to make sure the paint will not be harmed:
Soak with vegetable oil
WD-40
Rubbing Alcohol
Goof Off
(good luck)
BC52 #533449 04/29/2009 9:20 PM
Ex Hall Monitor
Ex Hall Monitor
BC52 #533450 04/29/2009 9:22 PM
3M adhesive remover.
soak and scrape
( citrus based ,neat and safe)
just-a-hacker
'49 3100 before '99
Thanks for the replys
