6 members (Ridgeback, rick46ia, Otto Skorzeny, klhansen, MNSmith, 1 invisible), 109 guests, and 4 robots.
Topics128,022
Posts1,055,373
Members48,420
#533208 04/29/2009 2:08 AM
I've got a 1951 2 Ton 6100SW Dump. My question is the HI/LO switch (dial). If the armiture is lined up over the HI range.this means it is in the high range right? I'm a rookie at the big bolts. This truck seems to be geared LOW!
beacon #533213 04/29/2009 2:16 AM
V
V Offline
Trucks were geared low in those days because they were built to haul loads over rough roads and the engines were way underpowered by today's standards.
crenwelge #533369 04/29/2009 2:06 PM
Saying it's geared low is almost an understatement. There's probably a 6 series gear on the high side and an 8 series gear on the low.
Like crenwelge said it had to be because of the lack of power up front plus no one with a truck thought of racing down those great roads back in the 50's.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
