| | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 38 | I've got a 1951 2 Ton 6100SW Dump. My question is the HI/LO switch (dial). If the armiture is lined up over the HI range.this means it is in the high range right? I'm a rookie at the big bolts. This truck seems to be geared LOW! | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | Trucks were geared low in those days because they were built to haul loads over rough roads and the engines were way underpowered by today's standards. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Saying it's geared low is almost an understatement. There's probably a 6 series gear on the high side and an 8 series gear on the low. Like crenwelge said it had to be because of the lack of power up front plus no one with a truck thought of racing down those great roads back in the 50's. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
