| | | Forums66 Topics128,154 Posts1,056,831 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 75 | So I am trying to figure out how to take off the cab, I just climbed out from under there and all of the bolts on bot sides seem like bolt heads. I may have been looking at the wrong thing or something but I have some buddies coming this weekend for a BBQ and to help me lift off the cab, so i want to have it ready for them so we can spend a little time moving it and alot of time with the beer and food.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | pull the front clip, then disconnect the steering, shift linkage, pedals, fuel lines, and wiring.
Then remove the two 1/2" diameter front bolts, and the 4 rear shackle mount bolts, then lift.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Wedge some sticks or blocks between the top of the frame rails and the rear cab bottom so it doesn't fall when the bolts come out. There's only 2 front bolts and 2 rear shackles. Don't show them the beer until it's on the dolly.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Don't show them the beer until it's on the dolly. Excellent idea!
~Jim
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Do not forget to disconnect the E-M brake rod thats the one I missed ,good luck Pete | | | | | Joined: Feb 2000 Posts: 90 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 90 | I also removed the doors and c-clamped a couple of 2x4s (10' I think)to the cab. 1 to the seat mount with the board evenly exteneded out both sides (this to the fwd face at the floor), the other attached at the rear and clamped to the rear door frame on each side. Now, with 4 folks I used these to lift it off of the frame. Then rolled the frame out from under. Next lower the cab onto your waiting dolly which can be made from those inexpensive 4 castor moving dollies (see Harbor Frieght) bolted together with 2x4s. Making a brace that bolts into the door openings (hinge bolts to latch side) is a good preventitive idea against any wracking that can occur. This is a milestone, have fun. cheers and good luck, Terry | | |
