3 members (Bill Marlow, 2 invisible), 109 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#533183 04/29/2009 12:49 AM
GRO
Offline
Apprentice
Apprentice
Can someone give me a quick lesson on which trucks came with 5 lug wheels and which came with 6 lug? I have a '63 C 10, long bed, step side. It has 6 lug 16 inch wheels. The spare (mounted on the driver's side fwd of the rear fender) has a 5 lug 15 inch wheel. All the wheels look original to me. I was always under the impression that 1 ton trucks had the 6 lug wheels.
Joe
'63 C10
Apprentice
Apprentice
from 37 through 70 chevy 1/2ton trucks had 6 lug wheels. from sometime in the mid 50's they were all 15". in 71 chevy trucks got front disc breaks and 15" 5 lug wheels unless they were 4wd then they were still 6 lug and 15" wheels.
3/4 and 1 ton had 8 lug wheels and they were 16" 17" 17.5"
now some time in the late 80" 3/4 ton trucks went from 8 lug to 6 lug wheels useing the old bolt pattern but 16".
so that is how you got 16" 6 lug wheels on your early truck. it does make it easier to get tires.
as far as the 5 lug spair it is on there to pass inspection
'88-'93 light duty 3/4 tons were the ones with the 6 lug 16" rims. The 2wd versions will work on the older ifs trucks, not sure on solid axle. 4x4 versions won't work, backspace is too deep.
Bill Burmeister
GRO
Offline
Apprentice
Apprentice
Thanks Bob. That's exactly what I was looking for. Nice summary.
Joe
'63 C10
