8 members (52Carl, Steelonsteel, TexasFarmTruck, Samantha, TUTS 59, Shade Baby, TexasJim50, Jims46),
87
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | It appears I have a leak on my 235 at the main seal ? How much should that repair cost ? On top of that the starter that I got from Napa 6 months ago is not working either, fortunatly there is a 3 year warranty. Any thoughts on this and are they related in anyway ? Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | RAK,
I don't think they are related at all. On the rear main leak, unless you are going to repair it yourself you could be in for a surprise. Most repair shops today wouldn't even know where to begin, and under a CYA policy would undoubtedly suggest you 'pull the radiator cap and drive a new truck under it'.
I think your choices would be, study the procedure and do it yourself, or find a repair shop that has been around since the dawn of time and has the proper mindset and knowledge to do this chore.
It is a common problem with these engines and can sometimes take several tries to repair properly while the engine is in the rig. It can be done satisfactorily and has been done satisfactorily many times. More input will be along soon I'm sure.
Stuart | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | A lot of times what is thought of as a starter problem, is actually just a poor connection in the wiring.(usually at the battery) I have seen starters that get the drive gear stuck in the 'out' position get fixed by either a few solid taps with a BFH on the starter itself, or putting the manual transmission(if equipped) in gear and rocking the truck forward and backward. The rear main is a little bit of a messy(oily) job, but you can probably do it yourself in an afternoon. | | |
