| | | Forums66 Topics128,186 Posts1,057,315 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53294 12/11/2005 11:25 PM | Joined: Dec 2005 Posts: 1 Junior Member | | Junior Member Joined: Dec 2005 Posts: 1 | i want to put a jag rear under a 55 to 57 1/2 ton short bed.
what rear do i need to look for as in under what style jag has the correct width rearend i know most are dana 44 but cant find info on width thanks | | |
#53295 12/12/2005 8:16 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I know that with the inboard discs, the old e type rears where the caddillac of hot rod set ups. Best bet is to find a jag board and ask them. | | |
#53296 12/15/2005 12:19 AM | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | I have had a couple of hot rods with Jag rears and I think that you should look for a sedan rear, as the E-Type is very narrow. The sedan may be a tad narrow unless you plan on running a deep wheel and a big tire. The E rear has a splined shaft (knock off wheels) and you need a weld on adapter which can be moved in or out a little, the sedan has a standard wheel flange that's fixed. I've seen a few F-100's with jags and they are probably close to the T F's width. If you have a choice get a rear with one piece rotors not the three piece composit ones. Also remember that the calipers use Girling fluid not DOT stuff unless you rebuild them with compatible rubber pieces. Those rears are a real eyesore in the cage, but a thing of beauty out in the open. Good luck. Richie Z | | |
