2 members (Forty9, baldeagle),
76
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53249 12/08/2005 5:25 AM | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | 1949 chevy 1/2 ton pickup with a 1954 235 engine. Not sure what make this carb is, it has an auto choke and I would like to restore back to manual choke and and add a hand throttle control. Can anyone identify the carb from my pictures, and how to revert back to manual choke, etc? Link to the pics is http://www.picturetrail.com/gallery/view?username=psy999&x=18&y=4 Thanks | | |
#53250 12/08/2005 6:29 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy DW, I believe the carb is a rochester model BC the model B carb is the manual choke/hand throttle version. | | |
#53251 12/08/2005 1:43 PM | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | Thanks Wrench Fetcher. Do you know if it can be converted to a manual choke/hand throttle? | | |
#53252 12/08/2005 3:06 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | To convert it you would have to change the top section. You might as well get another carb. They are a dime a dozen at the swap meets. The 54 up 235 will fit. The earlier ones had a narrower mounting bolt pattern. The latter ones had a different air cleaner mounting. Carbking has a bunch of them on the swap meet section or you could post in the parts wanted. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#53253 12/08/2005 5:09 PM | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | auto parts sells a kit to change from auto to manual for around $10.If your carb is good I would go that way.If you get one at a swap you;ll probly have to rebuild it first.
dan-pa
