3 members (Nick in Manitou, 49 panel, Hotrod Lincoln), 25 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#53249 12/08/2005 5:25 AM
DW
Offline
1949 chevy 1/2 ton pickup with a 1954 235 engine. Not sure what make this carb is, it has an auto choke and I would like to restore back to manual choke and and add a hand throttle control. Can anyone identify the carb from my pictures, and how to revert back to manual choke, etc? Link to the pics is http://www.picturetrail.com/gallery/view?username=psy999&x=18&y=4
#53250 12/08/2005 6:29 AM
3B Offline
Hy DW, I believe the carb is a rochester model BC the model B carb is the manual choke/hand throttle version.
#53251 12/08/2005 1:43 PM
DW
Offline
Thanks Wrench Fetcher. Do you know if it can be converted to a manual choke/hand throttle?
#53252 12/08/2005 3:06 PM
Riding in the Passing Lane
To convert it you would have to change the top section. You might as well get another carb. They are a dime a dozen at the swap meets. The 54 up 235 will fit. The earlier ones had a narrower mounting bolt pattern. The latter ones had a different air cleaner mounting. Carbking has a bunch of them on the swap meet section or you could post in the parts wanted.
1972 Chevy c10 Cheyenne Super
#53253 12/08/2005 5:09 PM
auto parts sells a kit to change from auto to manual for around $10.If your carb is good I would go that way.If you get one at a swap you;ll probly have to rebuild it first.
dan-pa
