7 members (rick46ia, delky, Samantha, Hotrod Lincoln, crenwelge, Bill Hanlon, 1 invisible),
118
Mod | | | Forums66 Topics128,261 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 108 | What parts do I need to hook up the power booster to my 51 1/2-ton? There is a plug in the center of the intake manifold which I assume I can use as a take-off point and the booster has a 3/8" hose fitting What size of fittings do I need to adapt one to the other? The manifold takes a 3/16 fitting so that would be a tapered fitting I believe - then can either be with hard line (compression fitting I assume) down to an adapter which will still need some hose I guess, or get a 3/16 - 3/8 hose adapter at the manifold and run vac hose all way down?
'51 Chevy 3100 Truck - OEM 216 Engine; three speed column shift transmission 6 Bolt disc conversion with dual master/vacuum booster 12V alternator conversion. 235 engine in waiting | | | | | Joined: Aug 2007 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 108 | Never mind - think I have it sussed - manifold fitting is actually 1/8 as it turns out - found a 1/8 to 3/8 barb hose fitting.
