6 members (Bwana-Jim, J Lucas, Hotrod Lincoln, Jon G, Otto Skorzeny, MikeE), 101 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#53199 12/06/2005 11:26 PM
Just wondering if anybody has an idea here?
I warmed up the eng (400 '67 C-10) and turned on the blower and all I got was cold air...I know the water pump is working cause the eng runs at the proper temp and you can plainly see by the gauge when the 'stat opens but for some reason there is no warm water getting to the heater core...some po put a valve on the water line going to the heater core but it turns freely like it is opening?...the temp of the line it'self is cool to the touch even when the motor is warm and the lever seems to be all the way over for heat ?
it's like nothing is going to the heater core...
guess I need to pull the line to see what's up? just wondered if anybody had run into anything like this
#53200 12/06/2005 11:53 PM
Riding in the Passing Lane
Feel all the hoses. Wearever the resriction is will be colder on the other side. If the hose going in to the heater is hot & the one comeing out is cooler the heater core may be stopped up. Also make shure the coolant in the radiator is clear full. If it is a little low it can get poor circulation.If all the heater hoses are hot you could have a heater door not functioning.
1972 Chevy c10 Cheyenne Super
#53201 12/06/2005 11:53 PM
Florida,
How cold does it get down in Florida smile
Come on up to balmy South Illinois and I'll show ya a heater...gettin down to 15 tonight grin
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#53202 12/07/2005 12:06 AM
I'm in N.Illinois, and drove the 54 today, heat worked great, and it was a wonderful 3 degrees, with a wind chill of -4..
Could be something simple as a new radiator cap..
Happened to me once, just before I was about to try to get the heater core out..
Steve
#53203 12/07/2005 4:23 AM
My 54 came with a brass heater line cutoff from the factory. Other models might be the same, at least for the recirculating heater.
Sounds like your valve is broken in the closed position, I got a modern replacement valve for $12 or so at my local auto parts store.
#53204 12/07/2005 8:31 AM
And the line that controls that valve might be off as well. (Or broken)
#53205 12/07/2005 5:03 PM
Ex Hall Monitor
Ex Hall Monitor
Quote
Your shutoff valve is broken in the closed position OR the heater core is plugged. A fairly common problem which ever it turns out to be.
#53206 12/23/2005 6:02 AM
Bingo Tiny...
I replaced the heater hoses and flushed the heater core today...the core wasn't plugged thankfully... it was the aftermarket valve set up the po had put on the heater hose line..even tho it would turn at the handle it was frozen shut inside...got good heat now...
