| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53199 12/06/2005 11:26 PM | Joined: Sep 2005 Posts: 67 Member | | Member Joined: Sep 2005 Posts: 67 | Just wondering if anybody has an idea here?
I warmed up the eng (400 '67 C-10) and turned on the blower and all I got was cold air...I know the water pump is working cause the eng runs at the proper temp and you can plainly see by the gauge when the 'stat opens but for some reason there is no warm water getting to the heater core...some po put a valve on the water line going to the heater core but it turns freely like it is opening?...the temp of the line it'self is cool to the touch even when the motor is warm and the lever seems to be all the way over for heat ? it's like nothing is going to the heater core...
guess I need to pull the line to see what's up? just wondered if anybody had run into anything like this | | |
#53200 12/06/2005 11:53 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Feel all the hoses. Wearever the resriction is will be colder on the other side. If the hose going in to the heater is hot & the one comeing out is cooler the heater core may be stopped up. Also make shure the coolant in the radiator is clear full. If it is a little low it can get poor circulation.If all the heater hoses are hot you could have a heater door not functioning. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#53201 12/06/2005 11:53 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Florida, How cold does it get down in Florida Come on up to balmy South Illinois and I'll show ya a heater...gettin down to 15 tonight
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
#53202 12/07/2005 12:06 AM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I'm in N.Illinois, and drove the 54 today, heat worked great, and it was a wonderful 3 degrees, with a wind chill of -4.. Could be something simple as a new radiator cap.. Happened to me once, just before I was about to try to get the heater core out.. Steve | | |
#53203 12/07/2005 4:23 AM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | My 54 came with a brass heater line cutoff from the factory. Other models might be the same, at least for the recirculating heater.
Sounds like your valve is broken in the closed position, I got a modern replacement valve for $12 or so at my local auto parts store. | | |
#53204 12/07/2005 8:31 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | And the line that controls that valve might be off as well. (Or broken) | | |
#53205 12/07/2005 5:03 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by Floridasurfcaster1:
guess I need to pull the line to see what's up? just wondered if anybody had run into anything like this Your shutoff valve is broken in the closed position OR the heater core is plugged. A fairly common problem which ever it turns out to be.
#53206 12/23/2005 6:02 AM | Joined: Sep 2005 Posts: 67 Member | | Member Joined: Sep 2005 Posts: 67 | Bingo Tiny...
I replaced the heater hoses and flushed the heater core today...the core wasn't plugged thankfully... it was the aftermarket valve set up the po had put on the heater hose line..even tho it would turn at the handle it was frozen shut inside...got good heat now... | | |
