2 members (Leo, GRNHydra), 84 guests, and 2 robots.
Topics128,060
Posts1,055,837
Members48,427
#53194 12/06/2005 11:06 PM
How do I tell which I've got? I'm a novice so bear with me...
On the dash to left of radio, I have a silver push button. Is this the choke (auto)? If not, what is it? :confused:
Steve
Today is the best day of my life!!!
#53195 12/06/2005 11:46 PM
Riding in the Passing Lane
It came with a manual choke. There should be a knob with a C on it. It should pull out to choke the engine. On a cold start pull out on the choke & when the engine starts push it in about 2/3. After the engine warms up a little push it all the way in. You just have to get the feel of it. Every engine is different.
1972 Chevy c10 Cheyenne Super
#53196 12/06/2005 11:52 PM
That's what I thought. However, there is no knob with a 'C' on it. Only the throttle knob and this silver push button. The carb is a rochester B which also indicates a manual choke.
Could someone have modified it to automatic? If so how could I tell?
#53197 12/06/2005 11:59 PM
If it is auto choke it will have a round chamber on the front of the carb. with a tube that goes to the manifold. A manual choke will have 2 cables. One to the throttle & one to the choke. Follow those cables to find which one is the choke.
#53198 12/07/2005 12:20 AM
I've got a hunch.
Have a look at the carb and where your throttle knob hooks up. I'm betting that the PO put the choke on the throttle pull when they busted the choke one off.
My truck is like this, and it seems to work well, so long as you don't need the throttle. I did buy a replacement choke pull, though. I'll put it in when I get around to painting the dashboard.
