| | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 75 | Ok so I am not great at driving a stick and well I will probably burn more clutch's out then I can afford to buy so I am changing the engine over to a 350 and am wondering about getting an automatic tranny, would the 700r4 work? I know this is not what most of you all would do with a truck like this but it is going to be my everyday vehicle, and it needs to be something I know how to use. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Sacramento is pretty flat, so I don't think you need to worry about wearing out the clutch.
If you must go the bent engine route, that is a desirable setup. Personally I think it would be eazier to learn how to drive and replace the clutch than drop the bent engine in.
| | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | Trucks like yours, prior to a 55.2, don't swallow a V8 easily. They tend to burp and fart a bit, needing to move the steering box over in order to clear the left exhaust manifold specifically. I would do all I could to keep an inline 6 in it. You might want to look into a 4.2 from a Trailblazer hooked to a modern overdrive automatic. I beleive that to be the ideal update for these old trucks that were designed for inline 6 cylinder.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Dec 2008 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 75 | Sacramento is pretty flat, so I don't think you need to worry about wearing out the clutch.
If you must go the bent engine route, that is a desirable setup. Personally I think it would be eazier to learn how to drive and replace the clutch than drop the bent engine in. Yes but I spend a lot of my time in San Fransisco and the Bay. As far as it would be easier to learn to drive it, you are right but I have a bumb leg from Iraq that makes that rather difficult. Also that 4.2 looks like a good swap, do you know where I can buy a new one at? Or at least a rebuilt one. I checked Jeggs already with no luck went to the GMDirect website they have them but for an arm and a leg, and I cant even tell if it is the right engine. Any help would be appreciated. | | | | | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | what do you plan for the old drivetrain? Chris 708-482-7646 | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | [quote=calhere Yes but I spend a lot of my time in San Fransisco and the Bay. As far as it would be easier to learn to drive it, you are right but I have a bumb leg from Iraq that makes that rather difficult.[/quote]
Sorry, I didn't mean any disrespect to one of our veterans. When you come to SF look me up and I'll have a cold beer waiting for you!
A 292 would be a fairly straight forward swap in your truck. They are eazier to find than a 4.2, and give plenty of torque and HP. You would have to remove the trans xmember for an automatic, fabricate new front side mounts, and a tailshaft support. The 700R4 will bolt right up to the 292. | | |
