| | | Forums66 Topics128,021 Posts1,055,351 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | On my 1952, 3600 what goes on the inside part of the bracket? Not the part the actual pedals are on, but the Opposite Side with the threads that mount to the frame. It appears to be worn but I am not sure if I should paint it or leave it so whatever slides on it to fits snug. The Whole Album ~Note the frame is upside down in the pictures. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Should have about a 3/4" (or is it 7/8") fine thread nut and a lock washer on the left end of the pedal shaft where it pokes through the outside of the frame.
Grigg | | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Yeah, I got that. But does anything attach to the shaft part before the threads that pokes out?? It looks slightly worn but I can't remember for sure | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | That portion is just a shoulder bolt that stops against the inside of the frame. It should be painted. | | |
