6 members (Jon G, Oswald, baldeagle, fonz8261, Hotrod Lincoln, 1 invisible), 76 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#531590 04/24/2009 3:26 AM
On my 1952, 3600 what goes on the inside part of the bracket? Not the part the actual pedals are on, but the Opposite Side with the threads that mount to the frame. It appears to be worn but I am not sure if I should paint it or leave it so whatever slides on it to fits snug.
The Whole Album ~Note the frame is upside down in the pictures.
cshamel #531612 04/24/2009 4:20 AM
Should have about a 3/4" (or is it 7/8") fine thread nut and a lock washer on the left end of the pedal shaft where it pokes through the outside of the frame.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #531740 04/24/2009 5:10 PM
Yeah, I got that. But does anything attach to the shaft part before the threads that pokes out?? It looks slightly worn but I can't remember for sure
cshamel #531743 04/24/2009 5:20 PM
That portion is just a shoulder bolt that stops against the inside of the frame. It should be painted.
