1 members (Charles in CA),
87
Mod | | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | Looking for any ideas or suggestions on assemblies that others have used? I have found a few universal kits online but would welcome any tried and true. Thanks G | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I put a pedal setup out of a 62 chev p/u in my 32 chev sedan 45 years ago and it went in quite readily. I used the hydraulic clutch. one out of a newer truck might work and oud give you pedal length appropriate for your vehicle
that vintage of pedal setup is pretty simple ron | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | Thanks Ron, I'm going with an auto tranny so will only need a single swing pedal with booster and MC on firewall. | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | swing brake pedal assembly I have used this particular swing brake pedal unit and fount it quite easy to work with. It has the holes predrilled that the booster mounting bolts through the firewall. So this unit mounts to the inside of the firewall and to the bottom of the dash panel. The pedal has adjustable swing. easy to work with. Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | |
