8 members (Ridgeback, GMCJammer51, Biermann, Danielbolt, sron48, GIJOE298, Phak1, DadsFirstPickup), 111 guests, and 3 robots.
Topics128,154
Posts1,056,835
Members48,456
#531138 04/22/2009 7:55 PM
Is there anything in the motor number that will tell me what year it is?
Everytime I go to the parts house they want to know what year it is, it's in a '49 chevy dually.
Thanks Russel
You should find most of the answers you need by checking the tech-tips at the top of the page. Use the search feature, this board is over ten years old and that question has been answered lot's of times. Here is some information that I pulled from the techtips INLINERS GMC CASTING NUMBERS
Welcome and enjoy the site.
GMC engine serial numbers do not seem to be well documented as to their correlation to particular production years. 228 engines were used from 1939 to 1952 according to the sources I read.
I am presuming that you know that the first 3 numbers of your GMC engine serial number indicate the displacement and your number could be preceded by the letter 'A' through 'G' , then 228 and then the serial production number. I found no sources that tied the engine serial number to a particular year.
In searching the http://www.oldgmctrucks.com/ site, I ran across a post from SlimSix, the engine technical advisor which may prove helpful.
He stated that the Date Casting Code, usually found on the same side as the block casting code can be used to narrow your possible production date.
It looks like a small raised plate with two screws and has a letter A-L which corresponds to Jan-Dec, a number 1-31 which is the day, and then a single digit which signifies the last number of the year.
So "B 28 6" would signify February 28, 1946 on a 228 engine. Your problem will be if your last number is "9" "0" "1" or "2" because each of those numbers could stand for two different years. 1939 or 1949, 1940 or 1950, etc.
A last digit of "3" through "8" could only signify one year because of the 1939-1952 production of the 228.
Join the oldgmctruck site if you still can't id your engine year. Some of the people there will forget today what you and I combined will ever know about these engines.
Let us know how your search turns out and welcome to the Bolt.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
