Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Hotrod Lincoln, UtahYork, 66flea), 163 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
#53154 12/05/2005 4:50 PM
1948 chevy 1/2 ton pickup with a 235 rebuilt in it ...
about every 4th time I push the starter there is this loud noise(gears clashing). Does that sound like the starter or the flywheel or both??
the flywheel and starter are from the replaced 216. I have heard several opinions from the guys around here but they are not stovebolt folks, so what do you think?
thanks...
Jimmy
#53155 12/05/2005 10:37 PM
Riding in the Passing Lane
It could be the starter is not matched to the flywheel. If the 216 flywheel was used when the engine was changed than it needs the coresponding starter. Or the starter drive on the end of the starter is going bad. You can replace it yourself fairly easily.
1972 Chevy c10 Cheyenne Super
#53156 12/05/2005 11:00 PM
the starter and flywheel came from the original 216...
who has the drive for the starter?
thanks for the advice
#53157 12/05/2005 11:32 PM
Any parts store should be able to get it for you.
#53158 12/06/2005 12:32 AM
Junior Member
Junior Member
i believe they made that starter drive gear with softer metal so it could wear as you kick it in and out so the flywheel, which is a lot of work to replace, wouldn't wear out - last month i thought my gear was worn out and pulled the starter and the end housing had broken - i had an old one for parts and love fixin without leaving the house - ticks me off that i move my truck a little bit now and then in compound low driving on the starter - never had too much trouble in the 3100's but my 250 weighs alot more - too old to learn? who me?
gramma said "if ya wanna dance, ya gotta pay for the music" she lived to be 104 - that's one tough "bolt"
#53159 12/06/2005 12:37 AM
Ex Hall Monitor
Ex Hall Monitor
I may be stepping into something here but I disagree. If what you are refering to is the overriding clutch, later to be called a bendix, it shouldn't make loud grinding noises. If it fails it should just allow the starter to spin up without turning the engine. Sounds to me like something not aligned right or something loose.
