9 members (cmayna, BarryP, Rusty Heaps, DadsFirstPickup, Gray_Ghost, BC59, UtahYork, Peggy M, 1 invisible),
137
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 5 New Guy | | New Guy Joined: Sep 2008 Posts: 5 | i have found a 60-62 school bus w/ a 4speed auto trans in it..if i use the trans and rear axle will this gear my truck up for highway speed?and is there a place for a pto on the auto trans...havent looked at this set up yet but plan to this weekend...im gonna use a 402 bb in a 56 6400...any help is appreciated
I love my trucks and hope to have them restored at some point
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 56chevyguy, if the tranny is stock to the truck, it will be a four speed Hydramatic, there is no provision for a p.t.o. on this tranny. This tranny does not have overdrive, the rear axle used with this transmission may have a lower ratio [numerically], and if it does, it will give more top speed, for any given input r.p.m., hope that helps | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its hard to imagine a Hydra-Matic being the right choice behind a 402, is that really what you are considering?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2008 Posts: 5 New Guy | | New Guy Joined: Sep 2008 Posts: 5 | well guy said it was an overdrive tranny so if its not and no pto i wont use it was just a thought...i do have another tranny spotted but want some info on it from u guys to c if it would be ok to use...its a 5 spd in a log truck..newer model like an late 70s or early 80s...has a 366 bb in it my question is 5th gear is over and down instead of up...is this an overdrive and if not would the 5th gear help out on the top end any...thxs for talking me out of the auto didnt really want it just looking for a cheaper way than a nv 4500 to get the truck up to maybe hyw spd...gonna have the rear end of the school bus chked to c what the gear ratio isthanks 3B and Oldsub
Last edited by 56chevyguy; 04/26/2009 9:20 AM. Reason: forgot to thank the 1s that replied
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | My guess is the log truck has a Spicer 5 speed direct drive. Is this of any help? http://www.chevyc60.com/the_transmission_page.htmIf not an OD transmission, then high gear will be direct, just like most all non overdrive transmissions. If you have determined you need an OD transmission then that's what you need, there are no substitutions (other than taller tires and faster rear axle gears). Also note that not all overdrives were created equal, ratios may vary from about .84 to a fast .61 or so. .8 is common in big truck transmissions, and .73 is common in medium to small transmissions. The .6x ratios are usually the second overdrive gears on some transmissions (double overdrive). Grigg | | | | | Joined: Sep 2008 Posts: 5 New Guy | | New Guy Joined: Sep 2008 Posts: 5 | thxs grigg...that site was helpfull...now i have something to go by as what to look for...havent made it back to the old log truck yet to see what it has for a trans or chk on the bus rear end but ill find out and let you know soon if im lucky OD but w/ my luck it will be a 1.1
