0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53138 12/04/2005 6:17 PM | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | I am thinking of using a gas tank from a late 70s camero in my 52 1/2. My Q.s are; will the fuel pump on my 216 be strong enough to pull the fuel out of the tank and up to the carb ( tank will be mounted in frame behind rear axle) since the 52 tank was gravity(sp?)feed to the pump. And to get the factory fuel gauge to read with the camero sending unit properly.( truck is 12v and i do have a reducer for the 6v gauge). Thanks | | |
#53139 12/04/2005 7:26 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Fuel tanks haven't been gravity fed since the 30's, I believe. You have a mechanical fuel pump, yes it will pull from a tank between the rear frame rails.
The sender in the camaro tank won't work with your stock gauge. The gauge works on a 0-30 ohm sender, the camaro is a 0-90 ohm sender. Putting a 60 ohm resistor in-line will not work. Best thing to do is to adapt a sender from the same era as your truck to the camaro tank. | | |
#53140 12/06/2005 6:11 PM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | My dad has put an electric fuel pump on all his cars between the tank and regular pump with a "just in case switch". Of course he in runnung those vaporlocking f##ds. jim | | |
#53141 12/06/2005 9:19 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Vaughn's right or put a modern after market fuel gauge somewhere in the cab and send to it the new camaro sender feed
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
