7 members (Gdads51, FAST55, Gray_Ghost, cmayna, tclederman, sron48, Hambone), 108 guests, and 0 robots.
Topics128,111
Posts1,056,258
Members48,437
#53130 12/04/2005 4:29 AM
I have a 1949 3600 pickup. I am pulling it apart and I am stuck with the gas tank. How do I separate the tank from the gas line going to the engine? I have the tank unstrapped, but I cannot see how to separate the tank under the truck. I see the cutoff screw, but cannot figure out how to get the tank ouf of the truck.
Any ideas? I know most of you know...so thanks in advance.
/Spencer Rogers
Mine has a short pipe nipple coming out of the tank, and then the valve screwed on to it.
To remove the tank I would drain the gas and unscrew the valve and pull the tank out.
Hope this helps
•1952 Chevrolet 3800 pickup
---All pictures---
' Offline
I have a '46 and when I pulled my gas tank out I unstrapped it as did you, then I was also able to see on the passenger side the petcock valve and where the fuel line goes in. My floor was out which made it easier, I didn't have to get under the truck.
Scott
The bottom of the tank has a pipe thread on it with an extension that goes thru the donut and then thru the floor into the valve. You need to unscrew it counterclockwise from the tank. Spray a penetrant up in there a day before twisting on it so you don't break off the fitting in the tank.
Curt B.
You Tube
#53134 12/05/2005 10:55 PM
You might want to spray that penetrant every day for 2 or 3 days before you unscrew it. It is a real PITA to fix THAT particular part on your truck. Don't ask.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
