1 members (JW51),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53130 12/04/2005 4:29 AM | Joined: Nov 2005 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 23 | I have a 1949 3600 pickup. I am pulling it apart and I am stuck with the gas tank. How do I separate the tank from the gas line going to the engine? I have the tank unstrapped, but I cannot see how to separate the tank under the truck. I see the cutoff screw, but cannot figure out how to get the tank ouf of the truck.
Any ideas? I know most of you know...so thanks in advance.
/Spencer Rogers | | |
#53131 12/04/2005 3:46 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Mine has a short pipe nipple coming out of the tank, and then the valve screwed on to it. To remove the tank I would drain the gas and unscrew the valve and pull the tank out. Hope this helps | | |
#53132 12/05/2005 3:46 AM | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | I have a '46 and when I pulled my gas tank out I unstrapped it as did you, then I was also able to see on the passenger side the petcock valve and where the fuel line goes in. My floor was out which made it easier, I didn't have to get under the truck.
Scott | | |
#53133 12/05/2005 8:45 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The bottom of the tank has a pipe thread on it with an extension that goes thru the donut and then thru the floor into the valve. You need to unscrew it counterclockwise from the tank. Spray a penetrant up in there a day before twisting on it so you don't break off the fitting in the tank.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#53134 12/05/2005 10:55 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | You might want to spray that penetrant every day for 2 or 3 days before you unscrew it. It is a real PITA to fix THAT particular part on your truck. Don't ask.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
