8 members (KEVINSKI, GMCJammer51, 66flea, WICruiser, Jon G, dt235sd, 2 invisible),
89
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53125 12/03/2005 4:10 PM | Joined: Dec 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 50 | Can somebody with a 261 tell give me a measurement of the dip stick tube at the block to the top. Also the length of the dip stick from top of the tube to the sump.
1951 Chevy 3100 5-window 261 cu in, 348 Head, Split Fenton Exhaust Offy with Dual Weber 2 Bbl Carbs
#53126 12/03/2005 5:46 PM | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | I have a '59 261 in my '56. The dip stick tube is 7" from block to top/dip stick is 14 1/8" from tip to where it meets the bottom edge of the dip stick cap. The cap goes down over the top of tube approx. 1/4") Hope this helps. | | |
#53127 12/03/2005 8:03 PM | Joined: Dec 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 50 | Mine is a 59 also. Hmmm. Mine is 6.5" and 15" respectively. Looks like some calibration may be in order. My tube was busted when I got th engine. Any other 261 guys have this info on theirs.
#53128 12/04/2005 12:43 AM | Joined: May 2004 Posts: 67 'Bolter | | 'Bolter Joined: May 2004 Posts: 67 | Mine is also a 59 261. Tube to the block is 7 1/8" and the dip stick is 15 5/8". | | |
#53129 12/04/2005 5:12 PM | Joined: Dec 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 50 | Mule: Stacking up all the dimensions you are within 1/8" of my stick reading. Do you also read overfill on your stick? The two of us are different from 56picup by 1 1/2" - 1 5/8".
