2 members (Rusty Heaps, Rmillerfly), 62 guests, and 2 robots.
Topics128,050
Posts1,055,757
#53125 12/03/2005 4:10 PM
Can somebody with a 261 tell give me a measurement of the dip stick tube at the block to the top. Also the length of the dip stick from top of the tube to the sump.
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
#53126 12/03/2005 5:46 PM
I have a '59 261 in my '56. The dip stick tube is 7" from block to top/dip stick is 14 1/8" from tip to where it meets the bottom edge of the dip stick cap. The cap goes down over the top of tube approx. 1/4") Hope this helps.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#53127 12/03/2005 8:03 PM
Mine is a 59 also. Hmmm. Mine is 6.5" and 15" respectively. Looks like some calibration may be in order. My tube was busted when I got th engine. Any other 261 guys have this info on theirs.
#53128 12/04/2005 12:43 AM
Mine is also a 59 261. Tube to the block is 7 1/8" and the dip stick is 15 5/8".
#53129 12/04/2005 5:12 PM
Mule: Stacking up all the dimensions you are within 1/8" of my stick reading. Do you also read overfill on your stick? The two of us are different from 56picup by 1 1/2" - 1 5/8".
