2 members (Gdads51, Flint48),
165
Mod | | | Forums66 Topics128,088 Posts1,055,995 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 60 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 60 | I,m interested in putting headers, and offy intake on my 292, I assume I will have to heat it with water for drivability, not sure whether a small 4 barrel, or should it run a 2 barrel. Also which headers would be the best, cast type, or tubular. It will be in my 65 k20 and may be used for some light hauling would I be better off with this cool setup, or just rebuilding it stock. Thanks, Coal | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Check out www.speedwaymotors.com They've got some header choices in both cast iron and tubular for the two different type of Stovebolt engines. Cast iron is going to be more trouble-free and a lot quieter. Tubular is just plain noisier. It's not a bad sound, but they do make more noise. For that many cubic inches, I'd probably err toward a small cfm 4 barrel carb. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Hey coal,
Everybody has their own way of doing things, so take all these opinions with a grain of salt. I am going with the Offenhauser intake, A 390cfm Holley, and a set of long tubular headers. There is no way my ears can tell the difference between one type of header and another. I am also building my own cold air box to feed the Holley. More important than carb and headers will be switching out your old distributor for a '75 or later HEI! The HEI makes a huge difference in starting, idle, and overall performance.
Best wishes,
Les | | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | Hi Coal - I did almost the same thing with my '64 C20. It was originally a 292 3 speed on the column. The motor was really tired so when we did the rebuild we used "propane" pistons, added a very mild cam, Clifford 4 bl intake and Hedman headers. (He's "Otis" in the Gallery.) We also changed the 3 speed to a 5 speed and it works great as a driver. We do tow a trailer with our '56 Chevy on it and it does OK - it works hard on hills or fighting strong winds. When we put the engine together I had a 465 cfm Holley carb that I figured would be pretty close to what it would need so thats what we ran it with. It ran OK but seemed a little weak at lower rpm and didn't seem to have "crisp" throttle response. The plugs looked really white but I was thinking maybe they were a heat range too hot. On a whim I tried a different carb. I had a box stock Edlebrock 600 which I figured would be too much for it but thought I'd see what it would do. I was amazed. It ran MUCH better - throttle response was better it would pull from low rpm better and the plugs were tan. I know that on paper that is way too big a carb for that engine - I also know the engine runs way better than it did with the smaller carb and the fuel mileage is the same. For what it's worth... | | | | | Joined: Jan 2009 Posts: 7 New Guy | | New Guy Joined: Jan 2009 Posts: 7 | Keep us updated. I'm going the same route eventually. My 292 is getting a rebuild later this year, and headers/intake are in the works. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2009 Posts: 60 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 60 | appriciate all the advice and anymore that someone would what to lend! | | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | I know it goes against everything the "experts" say but I have a Clifford 4 barrel intake on the 292 in Otis ('64 C20, long box) and have never hooked up the water heat to the manifold. We live in South Dakota and don't drive him a lot in the dead of winter but in plenty of cold weather and have never had a problem. No explanation as to why but have run it for several years without a problem. For what it's worth... | | |
