0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#530423 04/20/2009 7:34 PM
I read and followed with interest Doc Frohmander's Stovebolt stroker article. One question remains.. How big can I go with a 235 when it comes to Bore size? The 261 is hard to find. I would like to bore the 235 to use the 261 pistons from egge components. Can I take away that much metal?
No. You will strike the water jacket and that is why the cylinders are siamesed on a 261 and .080" over is generally the safe limit. If you haven't been here you may find some other useful info:
http://www.inliners.org/
You Tube
I did a little math, and it appears to be possible to use the 292 piston and rod in a 261, but not the 235. Offset-grind the crank to the 292 stroke, and you'll have a 292 cubic inch engine that looks like a 235/261. It gets the 261 cylinder wall a little thin, but it appears it wouldn't hit water. Boring the 235 to 261 diameter definitely isn't doable.
I recall that in the golden age the maximum bore increase for a 235 was 3/32", which would create 248 cubic inches with the stock stroke. This would be a bore of 3-21/32", still 3/32" less than a stock 261. What Jerry described above is similar to that which Tom Langdon calls his "Cadillac 261", which he wrote up in the 12-Port News a few years ago. Bob Torros also sold stroker kits for the 261 in the late fifties.
Hoyt
hoyt #573646 09/13/2009 12:47 AM
+.090" is a good place to stop. This pretty much limits the engine size, since the biggest you can offset the 292 rod is .211", and allowing only .002" to clean up the journal, the new stroke is only 4.1465". Total = 262".
If you want more stroke you either have to use a rod with a smaller journal such as Buick 248 (2.00"), or weld the crank.
Add up the cost of the rods, machine work etc. - much cheaper to just get a 261.
