3 members (Shaffer's1950, Southerntruck, Forty9), 81 guests, and 4 robots.
Topics128,263
Posts1,058,132
Members48,482
Page 2 of 2 1 2
Y
Y Offline
Hey, while I have the radio open, Total left field question. Any way to hook up an auxillary input to old tube radios? this is a subliminal question for can I hook up my IPOD.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
There is a member that participates here, and among other things he restores radios. I believe that he can do this modification. I believe that his first name is Jason but I may be wrong. Can anyone help me out here?
1951 1 Ton Completed
TRNIX,His name is Justin Rubsam. Thats his forum name also. From Minden,Nev. Stovebolter#14875
Hope that helps.
delux54panel,
thank you for the information. I believe that Justin Rusban does the modification that Yelostn78 was asking about.
Y
Y Offline
Thanks for the info. I actually just put the new tubes and vibrator in and the radio works well. I am getting a fluctuating tone in the background- but I can tune all the standard am stations around here and here it very well. Any thoughts? I wil also look up Justin.
Thanks for all the help.
Sam
Congratulations, that is great news.
If you are using a trickle charger, they are very handy but they can create some interfering noise. However, with old capacitors, the possibilities of problems are endless. It would probably benefit from receiving all new capacitors.
Y
Y Offline
I agree on the capaciors, I am going to try putting a ^V coil in between the trickle charger and the fuse on the power line. See if that helps at all for now. I am waiting to hear from justin on the input thing before I put it in the truck. If he does it, I will probably just have him check out everything and then send it back.
Thanks for all the help. It has been great.
jdl #530484 04/20/2009 9:37 PM
I build and supply JIM CARTER with the 0Z4's they are solid state and have a life time guarrantee, BILL
BILL #530518 04/20/2009 11:18 PM
JC OZ4s:
6v and 12v?
positive and negative ground for 6v?
The original 0Z4 and the one I build has no heater so 6 or 12 volt is no problem ,it's a full wave rectifier, takes in AC voltage gives out DC voltage,so polarity is no problem. It is also a direct replacement for the 6X5, witch did have the six volt "A" and is not needed, 6X5 is found in some car radios and house radios of the late 1930's and in to the 40's. Last year I restored a 1940 Zenith console radio, I replaced the 6X5 with one of my 0Z4 replacement ,
I build these using the original tube can so it looks 100% original , by the way I have several good 0Z4 inners, you could rebuild your own 0Z4 or make some kind of project ,they glow purple with AC on them , for the inners I don't use I'd sell them 5 for $1
Page 2 of 2 1 2
Moderated by  truckernix
