0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 71 | I am stripping the cab on my 53 3100 and one of the last holdouts is the light switch. I loosened the outer threaded portion you see on the dash behind the knob and the switch is now hanging free but how do you separate the knob from the switch to get it out of the dash?
Thanks | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | On the light switch under the dash you will find a spring loaded button, push it down and pull out the knob and shaft.Note: you may have to push the knob in a little.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | You must turn your headlights on to the full on position then push the springloaded pin in then your handle and shaft should come out. | | |
