0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | I have a 52. I know it was a dark blue, so I'm about 99% sure it was Mariner Blue. I remember reading someone that the interiors for the 52's were a Champagne color, but I'm not sure. I looked at the sticky for this forum and couldn't find Champagne. Is the dash and everything painted that same color? My cab is getting worked on right now, and once its done, they're going ahead and painting it, so I need to know, in detail, what everything should be to be back original. Thanks so much!!!!!
1952 Chevy 5 Window Restoration
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A sticky is a thread that appears on every page of the forum.?
I don't know what "I looked at the sticky for this forum and couldn't find Champagne." means, but did you use the search feature and search the Paint and Body Shop forum for +Champagne?
Denny Graham and others have posted a lot of information about that color and about what interior parts get painted what color.
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, 54TOW
The Paint Tech-Tip lists original names (used by Chevrolet). I do not think that "Champagne" was the name originally used by Chevrolet; however, the search I suggested above should give a lot of useful information about the Champagne color (I see you have now posted a link to one thread).
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Here is what I did, after more than a year of researching the correct color for the interior of my 52. I ordered a quart of the "correct" paint from Jim Carters. Once I got the paint I did a spray out sheet, and matched that to the 3 remaining original spots of paint in the cab. It was very close, and I liked the look of the paint. So I took a sample of paint and the spray out sheet to the good folks at Hightower paint supply here locally. I told them take there time and match the paint as close as possible. After two weeks they called and said come take alook. They had matched the paint almost exactly. I ordered a gallon ( I paid less that 1/2 for the gallon than the quart) Had them mix them together. I know 5 quarts is a lot, but this was my first time painting a vehicle. It turned out very well indeed. Also I didn't use a hardener, as I wanted a flatter finish. Also as a side note the original can got wet and the lable peeled off. Underneath the Carter lable was a Sherwin Williams lable. No code or name of the paint, but maybe an avenue to explore. | | |
