5 members (JW51, Gdads51, John L., DadsFirstPickup, 3B), 104 guests, and 1 robot.
Topics128,118
Posts1,056,305
Members48,439
I have been mounting my bucket type headlights--there is the bulb in the center which has two leads going to it so I assume high and low, then about three inches below center is another bulb--what light is this? For turning maybe--its a clear white bulb though??
That be the park light Davey, and yes, high/low beam are the wires for the main bulb.
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
Okay, thanks for that doc bob. heck I don't even notice the parking light on my modern car--Are they automatically on at the same time as the headlight--or maybe the first click perhaps. I wouldn't have thought they had them back then. What was the genisis for that?----dave
Ex Hall Monitor
Ex Hall Monitor
On my 38 there are three circuits going to the headlight housings: high/low/park. All three are connected @ a junction block under the hood on both sides. The first stop on the light switch powers the park lights, the second the dimmer switch. The high/low are controlled by the dimmer switch.
Thanks that will help me to wire it correctly!
