1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | I have taken a transmission off the 261 I recently purchased. I do not need it. I was hoping someone could help me Identify what I have and determine it's worth. The number on the trans are: 591568 F762 GM 3813389 It has a Dana Corp PTO Division unit on the side. The plate reads Chelsea model EZRWIC, [censored]'y 50997 H69. Is this just a plain old trans or something differant?
| | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | I am no expert, but if it says Dana on it, it automatically is not a junky old worthless thing. There are always 4 speeds with ptos around selling for 100 bucks at least. Wish I knew more. Good luck.
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Most likely a 1962 to 1969 model SM420 transmission, and obviously a compatible PTO.
Hang on to it, or give or sell it to a fellow Stovebolter, someone will be happy to have/use it.
Grigg | | |
