| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | I'm doing a '57 Cameo. We've swapped the front end with a Camaro. I'd like to put larger wheels and tires (the originals were 14's or 15's I think) on it. How can I do this and use original hubcaps? Someone suggested using larger (taller I think) tires but then somebody else that would make a rough ride. I'd think somebody has been down this road.
Regmudd | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might check with Wheel Vintiques or perhaps Mooneyes. I beleive they can set you up with a 15"-17" rim with the clips to be able to use the stock caps. I would suggest either the 15 or 16, whcih would be more compatible with the factory available trim ring sizes. A taller tire wouldn't be a good option in this case, as with the Camaro subframe, the ride hight is most likely lower than stock. Probably something along the line of a 28" tire would be good, such as a 235/75/15 or 245/65/16.
Bill Burmeister | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I went the same way with a 'vette frontend. I chose "Wheel Smith" as they had the 'artillery' wheels I wanted. They modify your hubcap to fit their wheels by welding an adapter ring to the cap. Offset was my way to get bigger tires under the 'fat fendered' street rod as I had lots of room to the inside of the wheel. Bigger wheels will get you fender rub if you are not careful. BTW, it ain't cheap. Four wheels plus the mod to the hubcap, beauty rings, powder coating, and shipping equaled $1175.00. That's not counting the $250.00 for new hubcaps plus the rubber.
