5 members (SmalltownTRKGuy, 3B, Peggy M, Steelonsteel, 1 invisible), 98 guests, and 9 robots.
Topics128,077
Posts1,056,032
Members48,433
#528605 04/15/2009 4:33 AM
its a 8 lug and i want to convert it to 5 lug disk in the front can i use a newer spindal off a 73 or so thanks
48 3 window truck
63 caddi
73 jeep rock racer
drive
48 3 window truck
63 caddi
73 jeep rock racer
You'll need to swap the entire crossmember from the later truck in, as the suspension is a completely different design (coils vs torsion bars). I know there's been a few guys on here that have done it. You'll want to get the rearend from the same donor truck, to keep the bolt pattern the same and to keep the brakes matched.
Bill Burmeister
