| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 11 New Guy | | New Guy Joined: Apr 2009 Posts: 11 | its a 8 lug and i want to convert it to 5 lug disk in the front can i use a newer spindal off a 73 or so thanks
48 3 window truck 63 caddi 73 jeep rock racer
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You'll need to swap the entire crossmember from the later truck in, as the suspension is a completely different design (coils vs torsion bars). I know there's been a few guys on here that have done it. You'll want to get the rearend from the same donor truck, to keep the bolt pattern the same and to keep the brakes matched.
Bill Burmeister | | |
