0 members (), 119 guests, and 2 robots.
Topics128,101
Posts1,056,182
Members48,436
Rebulding a generator/power steering pump combo. The existing conenser may work but I'd like to change it as part of the rebuild..Tried Jim Carter..not there. Anyone know where this can be purchased?
Keith
That condenser is there as a radio noise filter. Unless you're running an original-equipment AM radio, you'll never notice the difference if it's left off. If you want it there just for appearances, check it with an analog ohmmeter (the type with a needle, not digital). If it's working, the needle will rise, then quickly fall back toward an open-circuit reading. Ground the insulated lead to the condenser case before trying the test a second time.
Hey Jer-
You know I was wondering if it could have been for noise supression. I have 2 other generators. One has it the other doesn't.
Keith
Just a heads-up, Keith- - - - -if you decide to use it, always connect it to the Armature terminal. A capacitor (condenser) attached to the Field terminal will interfere with proper regulator operation.
If you are referring to the radio noise suppressors, they are available from Jim Carter and Chevs of the 40s (at least they used to be available; now they only show this suppressor ).
Here are instructions for installation of all the noise suppressors. (thanks again go to Keith Hardy for making this documentation available)
In the 1954 6v radio installation guide, it is suggested to run a flat ground strap for the head (from a bolt into the head, rear of the coil) to the firewall (to a bolt that hold the fender rod to the firewall).
What your after was originally called the "radio By-pass condenser" and it is just like mentioned above, a noise suppressor. They were originally a .3MF condensor...MF=microfarad. Anything available today is a .5MF. I can supply this in a kit with original style condenser, mtg. bracket, original style mtg. screw and the Warning tag telling you to not attach it to the Field terminal. PM me if I can help.
Ken
MF = microfarad, the unit of capacitance
micro ferrets?? Why isn't there a rolling on the floor laughing icon on this site? ohwell
There you go....something like that...LOL
