0 members (),
136
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | Somebody a while back posted a link on a bed painting test.they used somekind of black metal paint? Anybody have that link? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check in the Making a Bed subforum, it would likely have been from the MarK website
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yup, Mar-K was the ones that did it. I beleive they used Behr brand black paint (Home Depot).
Bill Burmeister | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | FWIW, I used rustoleum semi gloss black in the can. Put on two coats, looks good. I used an oil based paint so it would soak into the wood better. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Check out Mar-K, they had a whole tutorial and real world tests done on the bedwood with many suppiers and finishes tested. GOOD READING! http://www.mar-k.com/wood_finish_testing_ii.htmlTim | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Here's more info on the steps required for numerous finishes including step-by-step painting black. CLICK HERE | | |
