7 members (55shaker, TexasA&M48Truck, MickeyP, Ponchogl, Hotrod Lincoln, Nick in Manitou, 1 invisible),
126
Mod | | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I was surprised to find that the PO had painted over my chrome or stainless ( not sure how to tell )glovebox door. I was bored and decided to strip the paint, with a citris paint remover, before going over to my In-laws for Easter. I have a standard cab, no 5 window or chrome/stainless trim and thought it was usually painted. Anyone got an opinion?
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a little know oddity - not uncommon that chrome is found under painted trim, sometimes they ran outta the standard parts and used what was on hand .... don't blame it on the PO
Bill | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | The glove box door had a stainless outer and was painted in the center (small ribbed area) with the larger upper and lower band left to show the bright metal to match the speaker grill 47-November to early December 1951, 1952 and 1953 was a steel outer door and the complete door was painted top to bottom. Mike
| | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | OLTrucks, That's exactly the way mine was painted. The PO (or whoever)ran his tape line a little crooked and painted a little too much of the bottom bright metal...that is what started everything. Thanks for the info!
Chuck
Blue 50
