3 members (Otto Skorzeny, jay d, SmalltownTRKGuy), 112 guests, and 1 robot.
Topics128,049
Posts1,055,634
#527841 04/13/2009 10:53 AM
How close is too close to the radiator. I have about 3/4", to 1" between the two.
John54 #527844 04/13/2009 11:02 AM
I take it your truck is a 54? My 51 has about 1/2" clearance between the rad and the fan.
1951 1 Ton Completed
truckernix #527871 04/13/2009 1:36 PM
Although I understand that 2"-4" has been recommended for fan to radiator clearance in most vehicles, I also have about 3/4" clearance between my 6 blade fan and the radiator in my 54-235 truck. After 8K miles I've noted that my engine runs at thermostat temperature (180) and I've had no contact issues.
However, having it this close could/would be a serious problem if you ever had to drive through high water!!!
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
It's a 37 not a 54. John
John54 #527896 04/13/2009 2:41 PM
touching is too close, any year, you're fine at 3/4, probably OK at 1" with an original engine .... if it's more than about an inch it can pull too much air from the sides and not enough thru the rad core - look at a bunch of setups at a wrecking yard and you'll find anytime there's bigger space, there's a shroud to force the proper air flow .... if you swap a V8 in, use a shroud
Flxible #528338 04/14/2009 2:20 PM
On my 37, is the radiator suppose to go or can it go to the bottom of the space in the cowel? It is not a stock engine, all though it is a 261 six. I have another good four inches at the bottom that when I go looking for a new radiator I think I will have it made longer.
Is a two row good enough or should I get a three or four row radiator?
John54 #528344 04/14/2009 2:36 PM
I have mine dropped about 2" due to the fan being low on the engine, 250ci. If getting one made, going longer might help depending on the fan or shroud. If the fan doesn't pull air through it, then a longer core won't help much. Once below the filler panel air has a hard time getting to the core.
This is what I am installing, http://www.afabcorp.com/AFCO_Dynate...Code=80147N&Category_Code=hr_rod-rad , its about 3" thick, two big cores, the aluminum will cool much better then brass and weights about 1/3 as much. Unless you are running a big block, I doubt you need the longer core.
Joe
