| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Hello, My clutch pedal is installed but isn't currently attached to anything. Just wondering how it is attached to the trannie. I found a hook with a threaded end that I beleive is used but am not sure where it hooks up to? Any help would be great, thanks. | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | The threaded end goes through the opening in the clutch fork. One nut on each side of the opening. The hook goes around the lower end of the clutch pedal, it should look like a hook too.
Can send a pic if you need one. | | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | If you have a picture, I would appreciate it. It would help out alot.
Thanks! | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Take a look at The 1941 Shop Manual (Thanks to Keith Hardy) and you will note that the bolt and nut attach to the clutch fork. There should also be a return spring attached to a bracket just forward of the flywheel housing. Procedures for repair and adjustment can be found in the shop manual also. If you need a photo I'll send you one tomorrow.
My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | |
